Forum: Old versions
Topic: vdj and bcd2000 mic support
Im trying to help my friend with his setup, and I searched topics already on this subject - but none seemed to help me.
I want to get my mic to work with the bcd2000; I read on another topic that you need to enable WDM mode, how do you do this? What do you do after it's enabled? Can anyone give me a few directions on setting this up? It would be helpful.
We're running bcd2000 with vdj 4.2r1 and we have it hooked up to a Behringer EP2500 amp. We just want to get the mic working, the headphones work.
geposted Fri 10 Aug 07 @ 1:14 am
on the asio tab set it to "bcdj mode"
and on the wmd tab , try to enable it on the console software
the b-dj under global mode?
and i don't understand the second thing you're trying to say.
il find a picture to show you what i mean :)
give the global bdj mode a try
and then on the tab WDM what is set?
on the wdm tab
there are two options
IN A and Record Select
I have mic selected for IN A
and Record Select has In A Selecyed.
The global bdj mode does not seem to work, unless we're doing it wrong.
