Forum: Old versions
Topic: hercules mk2 software
With the Virtual Dj software that comes with the Hercules MK2 console can you download skins and add ons to it .
geposted Sun 12 Aug 07 @ 5:51 am
for the full list of what it can do aslo check the
comparison chart
so when i want to download skins, it has to say what on here: created for virtual dj....................
level required................
to allow me to download?
Home Edition
for olderskins for home users V3.4 (home ed)
newer skins need 4 X which is for pro users
the mk2 users can upgrade to pro at a
discount
Hello!
Is it possible to change the behavior of the buttons, especially for loops, fx and cues?
I like it a lot more in the pro-demo version.
i tried the console with the professional trail version and it worked good. My only problem is that the headphones dont work. There is sound but i can only hear the "mix"... when I "Split" the decks I hear both on the left side... "deck b" doesn't work at all i think.
I also plugged the heads in 3/4 (in the config i've seen sth. like this).
So I just want to know, if it works right in the "real" pro version.
for pro
on sound options
Inputs: none
outputs:headphones
card: mk2
channels : 1/2 main 3/4 headphones
Hay, this is a blog for "hercules mk2 software"
