i recently just bought MK2 and i have a stanton mixer as well.... can I use the multi instance with the mk2? if so, how should I hook up the MK2 and my mixer?? sorry im all new to this
geposted Mon 13 Aug 07 @ 5:52 am
yes u can,, n it best u look at skyfxl blog on how to hook up the mixer :)
geposted Mon 13 Aug 07 @ 6:40 am
you can use the mk2 to control one instance only
but it should work to play all 4 decks
connect it all up like this
ignore the turntables if you dont wish to use them
each line represents a dual phono cable
in vdj choose
input : none
output : external mixer
card : mk2
channels : 1/2 left 3/4 right
and on the mk2 software on advanced tick "external mixer"
and your good to go :)
in vdj choose
input : none
card : mk2
geposted Mon 13 Aug 07 @ 11:36 am
spinnaJ wrote :
yes u can,,
Oppsy,, sorri.. i meant this phase that i stated, its for the mk2 n external mixer.. sorry my bad if it cause confusion:) Should say it clearly.. n i just reread the original post and found out that what i say could misleading....
And yes,, mk2 could control 4 deck by opening 2 application of the software.
Cheers
geposted Mon 13 Aug 07 @ 12:40 pm
What is with me today,, haha,, ..
what i meant by opening 2 application is only using the mk2 itself to control,,haha,, i think i stop here. really worn out these few days.. :(.. need to recharge.................
Keep spinning,,
geposted Mon 13 Aug 07 @ 1:01 pm
