i think it might be from normal wear, but my jogwheels don't respond as quick & the crossfader as well. is there anyhting i can do i.e. replace crossfader,etc. i dont know what to do about the jogwheels. im getting tables in the near future, but i still like messing around w/ the dj console to make my own mixes. any help is greatly appreciated. thanks.
geposted Wed 15 Aug 07 @ 4:03 am
The Jog Dials (if I remember correct) Use a non-contact sensor to sense position. They can't wear out. Unless the bearing in the middle does.
The crossfader might be dirty.
Go to a computer store and buy a can of compressed air. Clean out the cracks and crannies with the compressed air.
Should fix you up.
Should fix you up.
geposted Wed 15 Aug 07 @ 4:46 am
