Hi,
My name's Kimi. I am a DJ from Barcelona (Spain). Some months ago i began to use Virtual DJ with the MK2 Hercules.
But there's a problem, when I connect the hardware to the table of mixing, i can hear a fucking noise when the volume of music is lower than the half.
If you can help me with this i would be frateful with you.
Thanks a lot.
Thanks a lot.
geposted Wed 15 Aug 07 @ 3:03 pm
Sounds like a ground looping problem. Information regarding this really needs to be stickied in the hardware forum. You should buy a ground loop isolator which should take care of the problem.
geposted Wed 15 Aug 07 @ 3:08 pm
kimi
would suspect andrew is correct if you can't get hold of an isolator quickly you could try removing the earth wire as a quick fix measure only and i mean only as a quick fix and see if that solves your problem...
Tayla
Tayla
geposted Wed 15 Aug 07 @ 6:06 pm
