Forum: Old versions
Topic: Help- What happen???
Last night i was practiced in my mac suddenly vdj program shut down by it self, did it twice.
anybody knows why did it ???? never happen before.
I have big party coming up, i am little worry now, may be is happen again.
geposted Wed 15 Aug 07 @ 6:05 pm
Without more detailed info, I can't really help much beyond this:
1. REPAIR your disk permissions (this may or may not be needed, but it doesn't hurt either way so just do it anyway)
Go to: (HD)/Applications/Utilities/Disk Utility.
Launch Disk Utility, select your primary hard drive with Mac OS on it (start up disk) and click on the "Repair Disk Permissions" button. There's no need to click on the "Verify Disk Permissions" button right above it, just repair them.
- VT ConQuest
(Visual Turntablist)
what where you doing exactly at the time
can you repeat it?
is it with just some songs?
what settings do you have for sound and performance
what mac do you use?
Hehe.
Thanks for asking all the appropriate questions sky.
I had to do something right away and just made that quick post to see if it would help. ;)
Thank you guys for the quick respond,
ConQuest i did what you said i repair the permision disk i hope it work?
skyfxl: i was mix for 20 minutes sunddenly vdj program shut down by it self in the middle of song, then happen
again after another 10 or 15 mnts. mixed music.
my config is ;
inputs- none
outputs- heaphones
sound card- 4.1 card
drive 1 - console mk2
my mac is: Macbook pro 15'
233 ghz intel core 2 duo
2gb memory--120 gb hard drive
mac os x v 10.4 tiger
