Hi i just downloaded the 5.0 just wondering why its not working.. doesnt load up. help plz
geposted Sun 19 Aug 07 @ 8:08 pm
the installer or the program?
geposted Sun 19 Aug 07 @ 8:19 pm
I am Pro user was running 4.3 ,I bought a Hercules MK2 controller ,was having some probs (would work,not wk,work...etc)
I read that loading latest ver . would help ,,I did a GIG yesterday and had to just stop mixing ,I put a bunch of tunes in playlist and started autoplay while I hooked up my backup rig ,,Well I made it thru to the end ...Today I tried to install V5 ,,,now I get error when I click desktop
icon and no VDJ4.3 or 5,,,,The console version works ,,but I just want my Pro ver. and to use MK2 as a controller...What went wrong?What
should I try?
Thanks Scott
should I try?
Thanks Scott
geposted Mon 20 Aug 07 @ 12:55 am
should I try?
Thanks Scott
should I try?
Thanks Scott
whats your system specification?
geposted Mon 20 Aug 07 @ 12:59 am
EVO Laptop ...xp pro,,SP2,,,P4 2.0GHZ,,1 GB ram ,,500gb ext drive with Music ,OS and not much else on lappy HD(30gb with 23 open)
geposted Mon 20 Aug 07 @ 1:05 am
I get instllation error after screen where you select which interface you want to start with
geposted Mon 20 Aug 07 @ 1:07 am
ok , try a reinstall of VDJ 5 , and the mk2 consoles drivers try the latest ones from the herc site
geposted Mon 20 Aug 07 @ 1:08 am
Should I blow away anything first?....any threat to external music drive?
Thanks for awesome reply
Scott
Scott
geposted Mon 20 Aug 07 @ 1:10 am
should I uninstall or delete anything before reinstall?
Is my external (music)HD at any risk?
Thanks
Scott
Thanks
Scott
geposted Mon 20 Aug 07 @ 1:58 am
Please download the Updates User Guide and read the message for existing users - Page 3 -
http://www.virtualdj.com/support/VDJ5-UserGuide_for_Updates.pdf
geposted Mon 20 Aug 07 @ 3:29 am
Thank-You for awesome support!!!!! I love vdj ,it isn't perfect ,but you folks never quit tryin.
I reinstalled VDJ(v5),downloaded Hercules MK2 drivers,started to install skins ,Still tryin to read how to use :
DJ-x350
Always
DAC2 new
Darkfun Skins
Perhaps they only work in previous versions?
Should I have blown away vdj B4 install V5?
I will read and learn again ,It is good for the soul ,,eh?
Again many thanks ,I am running again
Scott
DJ-x350
Always
DAC2 new
Darkfun Skins
Scott
geposted Tue 21 Aug 07 @ 1:56 am
