Forum: Old versions
Topic: meeeeedeeeee (midi)
hey all!
a little help if you could!
I'm trying to change one of my djm800 knobs to change the video transition selected.
Unfortunately, every time the knob goes to zero, it opens up that little window... instead, I would like to just change the transitions so that when i'm at the left-most (it's actually a gain knob) i would like to select the first video transition and when it's at the right-most... it should select the last video transition!
is there a way to change the feature that zero midi value opens up that window? or a workaround in how i program the knob?
I appreciate any help!
-Kedar
geposted Mon 20 Aug 07 @ 10:21 pm
