Forum: Old versions
Topic: numark vinyl cd time code fluctuation prodigy fx
Hey guys Im running prodigy fx on a dell 9100 laptop tweek for performance 1gb of ram cd time code mode
1- is it normal for the time code signal to vary from time to time while playing a song from 100% to 75% periodically
2- when i load a song sometimes it will start at the beginning and some times in the middle when in the middle , i would have to press the stop botton in software to get it to reset
3- does not hold que point after playing part of the song 1min into song que point gone
4-when playing song in cd time code mode song seems to fluctuate and sound like a poor quality mp3 intermitently,unlock time code song cleans up?
seems to play better!
5- regular cds - mp3s play fine in it
6- software buy itself plays fine also
GUYS this is Stat i have a couple of days left before 30 days is up, if its the players! You help would be Appreciated
geposted Tue 21 Aug 07 @ 3:47 pm
what soundcard do you use?
Obviously you are in version 4, WAIT for 5.0 if not ready for cue yet, most of these problems addressed ...
For #3 try to disable "smart cue" in TC setup.
Hey that was fast
im using the usb box that comes with numark vinly with version 4.3 r12
Hey is there going to be an updated verson of numark vinly or cue to verson 5
because numark is moving very slow!!!!!!!!!!!!!!
