It would be great to see a Clipbank plugin that can only load one clip at a time.
I'm sure a lot of people would find this helpful as they could put it as their default video go-to for when audio-only songs are loaded.
I tried to use the normal clipbank with that setting but it keeps displaying black (because it activates but then does not select the first clip in it's bank) so having only one clip and come easy coding, this should work right?
Some help would be great!
geposted Wed 22 Aug 07 @ 9:54 am
I Agree, this would allow people to use it for tracks that have no video.
The plugin should play from no 1, to the last loaded clip, then restart on 1, so people can load the clips in the order they want. Anhd it should start automatically when activated.
geposted Wed 22 Aug 07 @ 1:28 pm
Hi guys, that's exactly what I was thinking of!
I'm looking into writing a plugin for it, unfortuately I've only got a basic experience with programming but I'm gonna give it a go when the new skd comes out.
geposted Wed 22 Aug 07 @ 7:04 pm
I second that. I can't believe that it's not like that to begin with, but I'm not a programmer...
I'd use this feture with those options, but probably not without it.
geposted Wed 22 Aug 07 @ 7:19 pm
glad to see the support for the idea!
if any programmers find this and give it a shot, keep us updated!
if not, i might also poke around the sdk when it comes out and see if i can do anything at all
kedar
kedar
geposted Thu 23 Aug 07 @ 12:17 am
where can i get some clipbank animations?
geposted Fri 24 Aug 07 @ 12:01 am
dwight
for some reason they have taken norways post off the forum unless i've missed it somewhere but anyway here it is and its an excellent find by norway... http://sheepserver.net/v2d6/cgi/status.cgi
also i've done some extended clipbank videos that you may want to try.. http://www.youtube.com/watch?v=dxBDg6Fv-T0 they look better downloaded, there in mpg1 format
Tayla
Tayla
geposted Fri 24 Aug 07 @ 12:47 am
