Topic: DATABASE upgrade fix tool testers needed!
HI all in my blog you can find a tool i wrote during last two nights that fixed missing info for about 400 of my 7000 songs that has dissapeared after upgrade. I did not find a reason for it no to convert. (Can provide databases and data to devteam if it will help to track the issues.)
http://www.virtualdj.com/blog/lopez453/blog4551.html
it is for experienced users and process is halfmanual
DO NOT FORGET that you use it at your OWN RISK with NO WARRANTY and mostly BACKUP your files.
The tool does not modify no data, you must do it manually.
If there is someone able to make and executable/or better converter I could be maybe usefull, also I appreciate any comments and suggestions. The main goal is to find out if this principle works, then it can be cleaned up and improved to be more friendly.
geposted Wed 22 Aug 07 @ 4:16 pm
