can this be done much the same way we did 3.4 migration to 4.3 by simply renaming the virtualdj.exe file or is there to it?
thanks, Carlos.
thanks, Carlos.
geposted Wed 22 Aug 07 @ 6:35 pm
Covered several times - please search. But to answer your question - Yes.
geposted Wed 22 Aug 07 @ 6:58 pm
Any chance you have the links to posted already?
I of course did several searches, but if you don't type exactly what is needed, it does not find a match.
So, I don't know what else to search on to find that solution.
thanks for your help.
geposted Wed 22 Aug 07 @ 7:19 pm
That's why I answered the question also. Some maybe embeded in other discussions. But yes, just rename the virtualdj.exe to virtualdj_4.3.exe (for example - can be what ever you want) then install V5. The V4.x database is not harmed so if you create a new shortcut to your desktop you will be able to run V4.x just fine.
geposted Wed 22 Aug 07 @ 7:24 pm
