Forum: Old versions
Topic: Please help!! problems with the sound!!!
I have Virtual DJ 4.0 and I recently bought an Hercules DJ Control Mp3. The problem is that when i touch the jog wheel, the equalizer or press the auto beat buttons or de pc keyboard buttons i can hear a background noise that distorts the music that is playing. How can I solve this problem?? i have a very new laptop with core 2 duo and 1 gb of ram.
PD: With the 3.1 version that comes with de Hercules this problem is solved, but i lose all my CUES, because I copy the database into the directory of the 3.1 but when I execute the program I find all the songs with no CUES. How can I put all the 4.0 CUES into the 3.1 version??
Thank you.
geposted Wed 22 Aug 07 @ 7:26 pm
the databases changed from 3.x to 4.x , so going backward will be difficult.
If you own a legal copy of V4 then register and use your MK2 with V4 and upgrade to V5.
thanks cstoll. The problem of the noise can be solved with some configuration or driver updating??
Thank you.
We had this same problem with a Total Control and fixed by turning off Keylock.
Try turning Keylock off on both decks.
