I'm having a problem with the DMC2 with the Cue Pro.
The DMC2 came with the Cue LE and I bought the Cue Pro also because I was told it had more features.
But when I hook the DMC2 up to my Lap Top using the Cue Pro, The DNC2 flashes (PC Link Not Found
If someone could give me some pointers or help that would be great.
The DMC2 works great with the Cue LE, but I want to use it with the Cue Pro.
Rich
Music Search:
www.NuMusicHitz.com
Rich
Music Search:
www.NuMusicHitz.com
geposted Thu 23 Aug 07 @ 3:41 am
hi there rich seems you got it sorted , i aslo recomend that you
add your full cue serial to your profile to get the latest updates for it
http://www.virtualdj.com/fusers/modifuser.html
the full cue cd is a slighly older version
geposted Thu 23 Aug 07 @ 9:48 am
