Forum: Old versions
Topic: recomend laptop
hey, looking to purchase new laptop to run V5.0 any sugestions what specs should i look for?
1) money no object
2) or something resonable that will work just fine and with future updates
THANX
geposted Thu 23 Aug 07 @ 4:21 am
Sager NP9620. For the biggest powerhouse right now. 17 inch screen though and like something like 12 pounds.
wow! that thing is a beast thanx for the info @ Van Wilder what do you recomend that will get the job done on economical side thanx again
I use Sony Vaio Duo core, works great. Go to http://www.globalcomputer.com/ Global computer, they have great prices.
Good Luck, Hope that helps.
Rich
www.NumusicHitz.com
17" WSXGA+ "Glare Type" Super Clear Ultra Bright Glossy Screen (1680x1050)
- Arctic Silver 5 Thermal Compound
- Standard Dead Pixel Policy
- Intel Core 2 Duo E6700 2.66GHz w/ 4MB L2 Cache - 1066MHz FSB
- 512MB PCI-Express nVidia GeForce 7950GTX w/GDDR3 (User Upgradeable)
- None Standard
- ~ 2,048MB DDR2 800 (2 SODIMMS) Dual Channel Memory
- Standard Finish
- ~Combo 8x8x6x4x Dual Layer DVD +/-R/RW 5x DVD-RAM 24x CD-R/RW Drive w/Softwares
- ~ 160GB 7200RPM (Serial-ATA 150)
- None Standard - 9260
- HDD Raid Settings - OFF
- None Standard
- Internal 7-in-1 Card Reader (MS/MS Pro/MS Duo/MS Pro Duo/SD/Mini-SD/MMC/RS)
- Built in 1.3Megapixel Camera
- None Standard
- Sound Blaster Compatible 3D Audio - Included
- Integrated System Speakers - Included
- Internal Bluetooth 2.0+ EDR
- Built-in Intel® PRO/Wireless 4965 802.11 a/g/n
- None Standard
- Basic Black Business Case - Included
- Smart Li-ion Battery (12 Cell)
- 110/220V 120W Auto Switching AC Adapter - Included
- None Standard
- None Standard
- None Standard
- None Standard
- None Standard
- None Standard - Drivers & Utility Software Only
- None Standard
- None Standard
- 3 Year Labor* 1 Year Parts Warranty Lifetime Toll Free Tech Support (Extra 2 Year Labor Warranty through Xotic PC)
