Forum: Old versions
Topic: Running vdj 4.x and 5.x on same computer
I'm not sure if this has been covered yet, but can I run both VDJ 4.3 and 5.0 on the same computer, a la 3.x and 4.x previously?
geposted Thu 23 Aug 07 @ 4:42 am
EL it's all over the General forum -- use the search.
But YES, just rename the virtualdj.exe for v4 to something like - virtualdj_4.exe -- then install V5.
V4 DB is not effected by the install - it is only used to build the new V5 Database.
Excellent. Thanks. I wouldn't have thought to look in the general forum for that. Much appreciated.
Is it possible to do it the otherway around? i have installed v5 over v4 (made a backup first).. i want to Run V4 because have some issues with V5, is there a way to do the same thing, or what files do i need to copy? R
Just double click the vdj4.exe you backed up. Make a shortcut to desktop.
