Forum: Old versions
Topic: Need help with DMC2 Controller
I'm having a problem with the DMC2 with the Cue Pro.
The DMC2 came with the Cue LE and I bought the Cue Pro also because I was told it had more features.
But when I hook the DMC2 up to my Lap Top using the Cue Pro, The DNC2 flashes (PC Link Not Found
If someone could give me some pointers or help that would be great.
The DMC2 works great with the Cue LE, but I want to use it with the Cue Pro.
Rich
Music Search:
www.NuMusicHitz.com
geposted Thu 23 Aug 07 @ 5:00 am
Rich, please limit your posts on a topic to one thread. This has been posted three times now. Someone will give you some help. but please don't multi post on a topic. Thanks
My Bad, sorry
Have you got it sorted?
If you go to config-> remote control have you ticked the box for DMC2?
