Forum: Old versions
Topic: X Session Pro & Macbook Pro
Hey All,
I am running a Macbook Pro 2.4g 15inch.. I have Virtual Vinyl setup and its purring like a kitten. I have just got the X Session Pro and when I try to setup the midi controls in Virtual Vinyl it continually crashes when I start to move the faders on the mixer. I saw someone else post up the exact same problem but they didnt recieve a response. Can anyone shed some light on this or could anyone post up a file containing the midi config?
Also while I was trying to setup the midi, I managed to slide the crossfader from left to right once and save it before it crashed.. but when I load up VV and use the crossfader, the control is actually reversed - eg. when i slide the fader on the x session to the left, the fader on VV slides to the right??? Why is this?
Any help would be greatly appreciated!
Thanks all!
Flago
geposted Thu 23 Aug 07 @ 1:37 pm
are you using bootcamp or osx?
what value is set for midi + or - and which number for the crossfade
I am running OSX. I dont understand what you mean by the "+" and "-". Where are they set? It says CTRL 20 ??
I saw someone else post the same problem on here but has had no response yet.
Any help here would be greatly appreciated.
Thanks!
