Hey All,
I am running a Macbook Pro 2.4g 15inch.. I have Virtual Vinyl setup and its purring like a kitten. I have just got the X Session Pro and when I try to setup the midi controls in Virtual Vinyl it continually crashes when I start to move the faders on the mixer. I saw someone else post up the exact same problem but they didnt recieve a response. Can anyone shed some light on this or could anyone post up a file containing the midi config?
Also while I was trying to setup the midi, I managed to slide the crossfader from left to right once and save it before it crashed.. but when I load up VV and use the crossfader, the control is actually reversed - eg. when i slide the fader on the x session to the left, the fader on VV slides to the right??? Why is this?
Any help would be greatly appreciated!
Thanks all!
Flago
Thanks all!
Flago
geposted Thu 23 Aug 07 @ 1:37 pm
are you using bootcamp or osx?
what value is set for midi + or - and which number for the crossfade
geposted Thu 23 Aug 07 @ 1:41 pm
I am running OSX. I dont understand what you mean by the "+" and "-". Where are they set? It says CTRL 20 ??
I saw someone else post the same problem on here but has had no response yet.
Any help here would be greatly appreciated.
Thanks!
Thanks!
geposted Mon 27 Aug 07 @ 4:48 pm
