When i use automix it loads the next track in either deck the deck thats playing it skips sometime half the song and sometimes maybe 30 to 60 sec.
any ideas?
i have the latest ver. 4.3
P.S. its alway done this in every version i had...
any ideas?
geposted Fri 24 Aug 07 @ 3:22 am
You need to upgrade to V5 - AutoMix is fixed.
And, if it has been in every version then you have files with mix points set in the DB. You may want to look at the files BPM -> Edit AutoMix values
geposted Fri 24 Aug 07 @ 3:43 am
i agree with DjCali. the same thing happens to me......and my files are not with mix ponts set in the DB
sorry, i think it's a flaw and I did download v5...hate it
the automix kept mixing the same song
i'm back to the older version, at least i had more control
thanks
thanks
geposted Thu 27 Sep 07 @ 12:06 am
