in last version we were able to see column with album title & info, but in Version 5.0 it doesn't seem to appear in the window. How do we get the column info to show up in the Search window?
geposted Mon 27 Aug 07 @ 4:52 am
First: Read the manual located here:
http://www.virtualdj.com/forums/74929/General_Discussion/VirtualDJ_5_-_New_Features_user_guide.html
Second: right click on the column headers and you will get all the options for the columns including sort order etc. You can select which columns show by checking them off.
geposted Mon 27 Aug 07 @ 5:05 am
Already did this and it still doesn't show up. On the Search square/line I clicked and checked off all the titles I want to see and still only song, bpm & artist are the only 3 of the like 5 or 6 I checked off. I have a copy of the manual, read thru it, but haven't read it 100% yet, haven't had the time, hoping someone would have a quick answer. Thanks for your help.
geposted Mon 27 Aug 07 @ 5:13 am
What you are referring to is the fields that will be searched by the search function. If you right click on the library tabs (song, BPM, Artist) you will see the other id tags that are available and the ability to arrange their order.
Hope that helps.
Hope that helps.
geposted Mon 27 Aug 07 @ 5:17 am
Thank You!!! this worked
geposted Mon 27 Aug 07 @ 5:35 am
Glad to help
geposted Mon 27 Aug 07 @ 5:37 am
