Hi to all comrads.. :)
I'm very intrested on Russian language interface in VDJ..
What is your suggestion?
Best Regards..
Tiger
Best Regards..
Tiger
geposted Tue 19 Oct 04 @ 12:44 am
You can transate VirtualDJ to Russian if you want. Go here, and follow the instructions at the top of the page :)
http://www.virtualdj.com/addons/view.html?type=language
macourteau
macourteau
geposted Tue 19 Oct 04 @ 1:34 am
What am asking is this:
When i'm opening my playlist that included russian songs that written on russian letters, I can't see its letters..
I looked for fonts in VDJ directory but didn't found them..
How I can change fonts in this program?
Best Regards..
Best Regards..
geposted Tue 19 Oct 04 @ 3:44 pm
I always have the same problem with greek fonts.
My solution is this :
I opened the xml file from the default skin (with notepad)
and replaced all the "tahoma" fonts with "arial greek"
Try something simillar like arial russian... (i dont know)
Make a backup of the xml first.
Replace the one inside the .zip file
Let me know.
Let me know.
geposted Tue 19 Oct 04 @ 4:54 pm
