Am I noticing correctly that the old database (xml file) that used to store info about the files is no longer being used in V5? I updated several new songs today and looked at the database file to back it up and it didn't show as being updated with today's date. If so, great, was tired of always needing to be sure to back it up incase of the corrupt database file issue creeping up on me.
Also, why will the old playlists from past events not apear in this version? Can it not read the file that V4x created and saved? I have a couple of them that I really liked to use especially for cocktail and dinner hour. I could just select all the songs from it and load into autoplay, but now they do not appear.
Thanks for the help. No other problems I see just yet other than sometimes I have to load a long song (10 minutes or longer) twice before it will actually being loading. No stutters when doing that, but everything (screen) freezes up while the track loads.
geposted Tue 28 Aug 07 @ 5:12 pm
Please look at the guide and post any questions you still have after reading it - http://www.virtualdj.com/support/VDJ5-UserGuide_for_Updates.pdf
And to answer one question - look under the History item for old playlists? If they were in sub-folders let me know and I can help you get them back to be recognized.
geposted Tue 28 Aug 07 @ 10:32 pm
This topic has been locked as it is one of several discussing the V5 Database
Please find a consolidated discussion and information in this thread -
http://www.virtualdj.com/forums/76138/PC_Version_Technical_Support/VirtualDJ_5_-_Database_Issues_-_Explanations_and_further_discussions.html
geposted Fri 31 Aug 07 @ 5:46 pm
