Forum: Old versions
Topic: Remove Songs from Virtual Folder ..How??
Besides manually editing the XML database file, is there an easy way to remove songs from a Virtual Folder?
I'm using version 5.0 ... Thus far .... AWESOME!
TIA
geposted Thu 30 Aug 07 @ 10:06 pm
right click >> file operations >> delete :)
Will that delete the file(s) from the Virtual Folder only, or actual file from the hard drive itself? Obviously I'm only looking to remove it from Virtual Folder, not off my system.
just the virtual folder :)
