Forum: Old versions
Topic: projector resolution question
Hello,
Just a simple question. I have tomorrow gig and there is a video projector with max 640 x 480 resolution. Should i put output resolution to same from my laptop or more? My laptop supports output resolution all the way up to 1920x1280...
Thanks!
geposted Fri 31 Aug 07 @ 5:42 pm
Hey,
usually you should use the same resolution on the laptop and on the projector.
When you select a higher resolution the projector needs to interpolate the resolution. Results of this differ from model to model. I would suggest to try and go up from 640x480 stepwise to see which resolution fits your needs and/or has an acceptable picture quality, if this is nessessary.
