is this compatible with virtual dj? i got it from ebay but its a 2 in 2 out.. but dont i need a 4 in 4 out?
geposted Sat 01 Sep 07 @ 3:13 am
If you want to use VDJ prelistening (PFL) section, you need a card that has 4 outputs, yes.
Usually you then use 2 outs as mains and the other two for prelistening/headphones.
Lots of people here use the Maya44.
I don't know if the Maya44 is still on sale, butthis one is http://www.audiotrak.net/products/mayaex5ce/
geposted Sat 01 Sep 07 @ 1:51 pm
Oh, and this ...
if you are planning to keep the UCA202, you can still route the main out through the UCA and have the headphone out through your laptop.
You may use ASIO4ALL to select active outputs - http://www.asio4all.com/
For me, version 2.7 works best, as I use a similar setup like the one I mentioned above.
Hope that helps you ...
geposted Sat 01 Sep 07 @ 1:55 pm
