When I am using XP, VDJ detects my mixer/soundcard as a DXM01-USB, but when I am using Vista it only has the option for a 2 combination soundcard and then two drop-down boxes below where I select Soundcard 1 to be USB card one and Soundcard 2 USB card 2. Just wondering why it will not show the DXM-01 Icon like in XP.
Ive tried removing the drivers, trying different ports. Also the sound on the left side is noticebly lower output than the right so I have to have the gain higher on the left dial to match, is this a known issue?
Mike.
Mike.
geposted Sun 02 Sep 07 @ 3:41 pm
Just bumping this up. I managed to fix the sound level problem so its now the same level on both sides, but my VDJ Vista computer refuses to recognise a DXM-01 USB soundcard like the XP does. Theres no drivers it just configures itself as USB soundcard 1 and 2.
Has anyone else with a DXM-01USB mixer and Vista managed to get VDJ to recognise it properly?
Using Rev4.
Cheers
Mike
Using Rev4.
Cheers
Mike
geposted Fri 12 Oct 07 @ 5:45 am
