Forum: Old versions
Topic: Pro version couple of quick questions
Ok I upgraded to the pro version yesterday from the DJConsole version to use an external mixer.
All seems to be working well so I'm chuffed.
Got a couple of questions straight off.
- in my browser (bottom middle section) I have track name, artist and BPM but no longer have the track duration. Is there something I need to check to see that? I have tried dragging the headings but no luck.
- Is there a way to alter the colour of the buttons? It all looks much cooler than the DJC version but the grey controls at the top of the screen are hard to see at certain angles of my laptop screen
- is there a way to see the percentage pitch variation of a track? i liked the old function of +/- 2.5% etc.
Cheers.
Bob.
geposted Wed 05 Sep 07 @ 11:45 am
There are alternative skins available with what you ask - look at the variations in the skins section - http://www.virtualdj.com/addons/skins.html
As for the FILE BROWSER and SIDELIST sections - columns values are shared. Right click on a column and select the Length column. Now both sections will show the length of a track.
Ok I have found the answer to the last question i.e. just click on the BPM and it tells you the +/-
Oh great.
Cheers thats all three sorted.
