Forum: Old versions
Topic: M - Audio FastTrack Pro Problem..Please help
Hi.
I just bought Viritual DJ pro, and im using M-Audio FastTrack Pro.
I get right sound quality from only one deck?
Help please.
geposted Wed 05 Sep 07 @ 2:20 pm
Anybody know how to set up virtual dj with this soundcard and get fast track pro out 1/2 and fast track pro out 2/4 to have the same sound quality. I need this to work on my DJM 600 tonight. Please help me people...
My setup is
Inputs: None
outputs:external mixer
Soundcards: 2 cards +
Is this the right setup if i want to connect my laptop to the djm 600?
The problem i get is that one of the decks has bad sound quality?
Why are you using the 2 sound card option? The FastTrack pro loads ASIO drivers correct? Is the ASIO option available in the SoundCard selection drop-down?
Thank you for great help. It seems to work now:D
