Forum: Old versions
Topic: PROBELM WITH 1 TIMECODE
hey there, i can only seem to get one timecoded vinyl working..with the 2nd 1, everything seems to be working on screen, but i dont get any sound. further, im sooo confused on how to set my external mixer up instead of using the herc' mk2..iv tried changing settings in both vdj and mk2 settings...cant get my head around it. please help.
geposted Wed 05 Sep 07 @ 5:44 pm
I am not sure but..if you are using the demo version of VDJ it might only support one TT and TCV during the trial. After purchasing the full version both will be enabled. Like I started out with though..I might be wrong.
ok, i seem to have sorted it out..only problem left is with the external mixer that i cant seem 2 get working..and the sound is a lil ''digital'' with the tcv..is that normal or can you get perfect quality, especially when scratching..
It depends on what you got. Like if you have the full version I would be able to help you out, but you have the trial, its not going to work but its not the full program. Please clarify whether or not you have the full pro version or just the trial.
