Forum: Old versions
Topic: Screen Goes Blank after using for several minutes
Just wondering if anyone else is getting this problem. I am currently trying to use the trial version of virtual DJ and after using the software for a random amount of time, the screen will go blank, yet the software still continues to play the current song. All functions of the computer are still available but I can't see ANYTHING.
I have to restart the computer everytime this happens. I am afraid to buy the full version for fear that this problem will happen with that also.
IF anyone else is having this problem do you knkow a fix?
geposted Thu 06 Sep 07 @ 3:37 am
What are your system specs? And what exactly are you trying ? Are you just playing MP3's or are you trying videos as well?
I had exactly the same problem , don't know what caused it . At the time i was using a low spec laptop, when i upgraded my laptop the problem went away.
