Forum: Old versions
Topic: my tcv don't move backguard
hi, i can't make my tcv move backguards
playing in realtive mode, i put the needle on the tcv and it starts, zero latency
i can move forward,, i cant grab & stop, but when i try to move backguards it moves forward
i'm using an audygy 2zs, and the one on the laptop,all with asio4all
my laptop is 1.9mhz and 1256ram
anyone have some solution?
geposted Thu 06 Sep 07 @ 8:06 pm
what version do you use?
i'm traying the version 5
nobody? don't let me down guys
I don't know about audigy and i will never recommend such a card.
You need a soundcard designed for dj/timecode use for this, and the full version of virualdj (demo should work too for a while)
Then it works perfectly.
well, i've just tryed in some technics 1200 of a friend and it work great
so the soundcard works really good, and 24bits of quality
at this point, is obvious that my gemini turntables suck
but the strange thing is that when i play regular records (vynil) they work fine, but when i play the tcv, they don't move backguards
any idea of what is failing in my turntables?
is not the needles cuz i tryed mine's in the technics
