Topic: Serato timecode plugin?
Funky-TPRO InfinityMember since 2006
Serato timecode plugin with 100% needle drop support, when ?
Or... any other, so we can use others timecode vinyl.
geposted Fri 07 Sep 07 @ 4:55 pm
mspinky has a VST plugin.. that should work with VDJ right?
geposted Fri 07 Sep 07 @ 6:10 pm
mspinky working with needle drop in VDJ?
what about serato?
geposted Fri 07 Sep 07 @ 7:18 pm
Have you tried it?
geposted Fri 07 Sep 07 @ 7:20 pm
did the generic serato plugin get released yet?
geposted Sat 08 Sep 07 @ 2:05 am
To some.
geposted Sat 08 Sep 07 @ 3:35 am
Mantahoe wrote :
Have you tried it?
No, I know this setup works in other DJ apps using VST plugins, so I guess I could/should work with VDJ. I have not actually tested it though.. Never use VDJ with TCV anyway (or put better, only use VDJ if I have to use video).
geposted Sat 08 Sep 07 @ 6:55 pm
Any news on this Serato Plugin yet ?
geposted Wed 19 Sep 07 @ 8:23 pm
just so you know there is a delay in the serato record with virt dj.. I also tried final scratch with no success. but now you can use the numark cue records with virt dj and get 100% success.... because everything else is just a toy...
geposted Fri 21 Sep 07 @ 3:40 am
RuudboyPRO InfinityMember since 2007
Thats all wonderfull, but if you live in Vietnam or a bunch of other countries in the world you are not able to get the Vinyl! and even if Atomix will sent them out, they will be warped and customs will charge me 200% import duty! Since i have a pair of serato and a pair of torq vinyls i need that plugin!
geposted Fri 21 Sep 07 @ 6:51 am
cstollPRO InfinityMember since 2004
Ruudboy wrote :
Thats all wonderfull, but if you live in Vietnam or a bunch of other countries in the world you are not able to get the Vinyl! and even if Atomix will sent them out, they will be warped ...
And you draw this conclusion because you have ordered and received Warped Timecode?
geposted Fri 21 Sep 07 @ 7:08 am
Ctroll, two issues:
1) I did not order from you guys because 1) Vietnam was not listed at that time... 2) I ordered Vinyl here before and it arrived warped
2) The tax issue is fixed nothing to do about that!
If vietnam is now on the list ill be happy to order them! If they arrived warped do you sent again?
geposted Fri 21 Sep 07 @ 7:18 am
