Forum: Old versions
Topic: Help-at gig Pitch timecode cd issue
hope I explain this right...
using timecode cds.
whe I load a song and I have the pitch slider on the denon controller at plus 2.0 the song in vdj for that side is at 0 instead of at plus 2.0. when I slide the controller pitch to 0.0 vdj pitch then goes down minus 2.0.
how do I fix this where they match? if I recall I had the same thing with 4.3 and I think its just a setting. what does the setting need to be?
my config currently is
mode: smart
smart cue box is ticked
clear sound is ticked
thanks for the help! I'm at the club now using vdj5.
geposted Sat 08 Sep 07 @ 5:53 am
update...
when I changed the setting from Smart to Absolute it worked however I then could not get the song to stay on the cue point.
I would hit the pause button to get to my first or 2nd cue...whichever one I chose. When I would start the song with the timecode at 00:00 it would revert back to the beginning of the file instead of at the cue point.
if its a setting what is it? relative does nothing...no matter pitch up or down on controller song stays at its original bpm.
just frustrating when I have the pitch slider plus 2.0 for a song I just played and then the next song loaded onto that deck is 0.0 on the software but when I slide the pitch slider on the controller back to 0.0 the song on that deck in the software goes to minus 2.0
Go into your Config -> Option and Disable the Pitch Reset on Load.
Thanks knew it had to be a setting. I tried the wrong one.
thanks again.
