Forum: Old versions
Topic: how to tag
does any one KNOW HOW TO GET HELP WITH THIS PROBLEM .If i have a load of files mp3 type and they are not named what can i do so i dont have to type aech one by hand.ive got about 160 gig worth.does itunes file work on v ,dj
geposted Sun 09 Sep 07 @ 8:02 pm
try tag and rename :)
www.softpointer.com/tr.htm
use www.mediamonkey.com it has a feature that you can get the tag from the filename. it will save your life, give it a try!
