Forum: Old versions
Topic: USB sound card interface recommendation
Hopefully this is the right place to ask this. I have searched this forum as well as several others and have not gotten a good recommendation of what a good USB sound card to purchase for Virtual DJ and my Laptop would be. I see that several people are using a "Maya 44 USB" but it looks like the "Maya 44 USB" is out dated or not sold at several stores. I was wondering what You guys (Virtual DJ) recommended for a interface card or should I continue to search for an Maya 44 USB? And does that USB card work well with Virtual DJ?
Thanks for the advice.
geposted Mon 10 Sep 07 @ 3:39 am
If your looking for portability I think the Hercules Mk2 Console is the best option. It will fit in your laptop backpack nicely, has a very resonable soundcard and is a good controller for the VDJ program also.
^^+1
Also came with a DJC editon of VDJ which u can registered as home edition user n on top of that u could upgrade with discount in the future:)
is there something similiar but is just the mixer portion? i'm ok with controlling the decks from my laptop, just want to be able to use an external mixer and headphones
to use those options you would need VDJ pro
perhaps a maya 44 usb soundcard would suit your needs
ok so if i buy VDJ pro, what options are available AFA mixers go
no i mean what options for external mixers to control VDJ are there?
well if you want a midi mixer (to control the program) the best option is the nuo4 currently
or if you just want to mix the output of the soundcard like using cd players any mixer will do :)
ok thanks, what about something that doesn't cost a thousand bucks? lol
