Forum: Old versions
Topic: HELP WITH BCD2000 OR SHOULD I UPGRADE MY CONTROLLER
I AM INTERESTED IN CONTROLLING/MIXING/SCRATCHING VIDEO WITH A CONTROLLER. I HAVE A BCD2000 & JUST CANT SEEM TO GET IT TO WORK??? IT SEEMS TO CONTROL ALL FUNCTIONS EXCEPT THE PLAY & JOG WHEEL & DOENST PLAY AT ALL??? CAN THE BCD2000 CONTROL VIDEO???? I HAVE AN ACER ASPIRE 9410 LAPTOP (2GB RAM,DUO CORE 1.6GB,120 GB HD,AN 320GB MAXTOR EXTERNAL HD,MAYA 44,ECT)..I HAVE INSTALLED ASIO 4 ALL DRIVERS, I CAN SEE THE BCD2000 IN THE SOUNDCARD SETUP BUT NOT NOT THE REMOTE CONTROLL SETUP??I DO SEE AN OPTION FOR THE BCD IN THE MIDI CONFIG OPTION WHICH I SELECTED AN THATS HOW I GOT THE SOME OF THE FUNCTIONS ON THE BCD TO FUNCTION, I DONT SEE AN OPTION FOR THE BCD2000..IT STILL DOESNT PLAY ANY FILES VIDEO,MP3,KARAOKE??? I AM KINDA FUSTRATED & NEED A MOBILE SYSTEM THAT IS EASILY TRANSPORTABLE FOR VIDEO MIXING. I HAVE THE TCV & TURTABLES THAT WORK FINE, BUT I AM TRYING TO TRAVEL LIGHT WHEN I DO MOBILE GIGS...I AM OPEN TO SUGGESTIONS SHOULD I CONTINUE TO TRY TO WORK WITH THE BCD2000 OR BUY A MK1 OR MK2 OR NUMARK TOTAL CONTROL TO MIX VIDEOS ON THE GO???? I AM USING 5.0..ANY HELP WOULD BE APPRICIATED...THANX
geposted Mon 10 Sep 07 @ 4:21 pm
suggestion number 1 - don't use all CAPS to post. It makes it difficult to read and it implies you are SCREAMING.
suggestion number 2 - Register your VirtualDJ 5 - http://www.virtualdj.com/fusers/modifuser.html
suggestion number 3 - use the forums search features, there are plenty of topics on BCD2000 setups
