Forum: Old versions
Topic: Key Lock
OK guys, I am running VDJ 5.0 on a DELL Dimension 9200 with a:
2 duo core 1.8
Nvidia 7900gtx 512 ram video card
80 gig hard drive
2gig of ram
Total control by numark
And y use the SERATO audio card…
Here is the problem, when y turn on the key lock and pitch + or – the sound is bad, it’s like really choppy, how can I fix this?
Please help.
geposted Tue 11 Sep 07 @ 3:56 am
What performance settings are you using?
i have only used the auto.
try to put performances slider to fastest , latency auto n tick/untick safe mode n overclock n c if there any different..
ok, it's sounds a little better but not like my denons, if i buy a difrent audio card will it sound better?
if so, recoemnd one, thank you.
You need to adjust your settings, until you find the best settings that work with your computer. There are lots of posts around here that have good instructions. For one I think if you shut safe mode off you get better sound. I read lots of people have problems with configuring VDJ on Dells.
