hi all,
hope you can help. im thinking of buying this program but need some advice on the above.
if i put headphones ito my current soundcard - soundblaster live value - all i can hear is the same track in both ears. do i need a new soundcard so i can hear as i would on dex? I basically want to be able to hear 'deck a' through my pc speakers and 'deck b' through my headphones
i hope this makes sense.
geposted Tue 11 Sep 07 @ 11:59 am
VDJ is able to do that. You have to purchase the full version in order to change those settings.
regards.
regards.
geposted Fri 14 Sep 07 @ 12:37 am
