Forum: Old versions
Topic: hooking up real vinyl to play threw V.D.?
im wanting to play my real vinyl records instead of the timecoded vinyls how do i switch back and forth between them?? and would the real vinyl still show the beats and info on the virtualdj screen on my pc??
i got... Virtualdj Pro, Timecoded Vinyls, Soundcard - ESI U46DJ Professional USB Sound Card, Numark - BATTLE PAK v.4
ps i know how to hook it all up to play my timecoded but i need help with the real vinyl setup. thanks
geposted Tue 11 Sep 07 @ 4:18 pm
In VirtualDJ 5 the timecode_bypass option was added back to the environment.
Need to create a keyboard shortcut to activate the bypass.
Now it was reported that you will be able to apply effects and E.Q. settings through VirtualDJ. I have not tried this so I can not confirm. As for the wave display, this should also work, however; it will be real-time. You won't have any lead time as VirtualDJ can not see into the future of what is about to come across the needle.
Create the shortcut and play with it.
