Forum: Old versions
Topic: DJ Console Effect buttons playing up.
Occassionally whilst doing a set I'd press the effect button and the effect would either flicker on then off, or not react to at all to the button being pressed.
Concerned what to do.
geposted Wed 12 Sep 07 @ 3:58 pm
Right did both ideas,
The bug is still there however less obviously than before, however when it does play up, it can play up two or three times in a row.
Hmm strange.. i couldnt say it malfunction rite as it still react on wat it supposed to do,,.Wat drivers r u using, OS? How long did u have ur mk2? Maybe it best to sent ticket to herc site n explain to them..
Have had it for less than a year. This has only been the case since changing drivers to 2007, however have changed drivers back to the original ones on the CD with the console.
Getting a pair of turntables in due course, so am slightly concerned to say the least.
its still underwarrenty give herc a call,
Have u mail at herc support? Tell them ur problem n they will help ya:)
