Forum: Old versions
Topic: Maya44 on 32-bit ASIO resolution - Can't select 16-bit!
Hi All,
I'm using VDJ 5.0, a maya44 usb soundcard with the v2.85 drivers and 32-bit Vista on a Dell M1330.
For some reason the ASIO resolution setting is on 32-bit and 16-bit, 24-bit are greyed out. I'm getting problems with the time-code vinyl signal quality (all over the place) and pops/cutting of the sound are going on (even when not using the TCV). I've calibrated many times, used the asio4all drivers, re-installed vista - no changes.
Is there a way to get the lower bit rates selectable? Would this even be the cause of the above issues? I've got another theory that it's related to relatively high DPC (deferred procedure calls) levels - as when even using the internal soundcard I get major stuttering with using the Master Tempo and changing the pitch.
Thoughts?
geposted Wed 12 Sep 07 @ 4:03 pm
My 16bit button is greyed out in the Maya controls too. I don't know why though.
Gary
