Forum: Old versions
Topic: Skins on a MAC help
I just put VDJ version 4.3.r13 on my mac mini and its all good. I would like to use the Mix Station SV v4.2 skin. I downloaded the file fine and all but its an EXE file so the mac doesnt know what to do with it. Please help, thaanks!
geposted Fri 14 Sep 07 @ 4:07 am
I've got the same problem with my new Macbook pro, I can'tinstall any skin or audio plugin
The skin and audio effect files have not been recoded for Mac yet. I believe it is in process. They are coming soon!
if you need a particular skin send me a pm requesting it
and i will try to email it to you,
skins will be uploaded in mac format soon
as to audio fx the developers need to recode them to mac first
