Hi,
I am new to VDJ and I have just purchase a Dac 3 to go with it. The main problem I have is that when I touch the jog wheel the song skips forwards or backwards depending on what why I have touched the wheel. Is there any way in which I can turn this off and use the jog wheels to search through my song lists? I find having to push a button everytime you want to go down your song list very strange.
Please help a newbie
many thanks
Justin
many thanks
Justin
geposted Wed 19 Sep 07 @ 9:30 pm
there is a mapper for pro users to adjust the behaviours
hope to see you with us soon :)
geposted Wed 19 Sep 07 @ 9:34 pm
Thanks for helping, can I ask would this allow me to use the jog wheels to search my song lists? I keep hearing bad stories about version 5 crashing, is this the case? Do you get free updates when you purchase the licence?
many thanks
Justin
many thanks
Justin
geposted Wed 19 Sep 07 @ 9:38 pm
Yes, n with lots more:)(skins, plug in etc)
geposted Wed 19 Sep 07 @ 11:15 pm
Yes, with the mapper you can hold down SHIFT and scroll through files using by turning the jogwheel. You can also toggle the jogwheel between pitch bend and scratch.
geposted Thu 20 Sep 07 @ 1:10 am
