i get a terible sound (the same is on the TV when you don't get signal) when i have played a long time with VD
anyone got the same thing??
geposted Fri 21 Sep 07 @ 6:49 pm
Which version are you using ? Is it the demo ? If it is a crack... sorry, buy the software. http://www.virtualdj.com/purchase/
geposted Fri 21 Sep 07 @ 7:30 pm
I am having the same issue. I am using the full pro version. I have a X4 Duo Core 2.33 Mhz and 3 GB of ram on Win XP sp2.
The if I use the Herc DJ controler as my sound card it is bad sound right off the bat but the other drivers have the same issue after a time.
geposted Sat 24 Nov 07 @ 7:53 pm
If your having problems with VD, you should really see your doctor. There are pills to help with this kind of problem!
geposted Sat 01 Dec 07 @ 10:13 am
