I am a recent user of VDJ and am loving the new Version 5 especially the new browser
One thing I cant figure out is,
Can you change the way the system CUEs to the way it would on a Denon or Pionner. So I can select the frame when trying to set a cue
Also I would like to turn off the scratch because I keep hitting the wheel on DAC 3 by acident
Thanks guys sorry if its an obvious question
geposted Fri 21 Sep 07 @ 9:26 pm
Bump.
I sometimes run into the same problem.
geposted Sat 22 Sep 07 @ 7:15 am
about the dac 3, please go to config/remote control and set the required settings..
about the cues, could you be a little more precise?? how do you mean "way the system cues"
cheers
DJ Rudra
geposted Sat 22 Sep 07 @ 9:37 am
If you mean frame cueing where the music 'stutters' allowing you to adjust the cue point, VitualDJ does not have this function. It allows vinyl-style cueing only.
The only way to currently get frame cueing in VDJ is to use timecode CD's with a CD player that does this.
Download the DAC-3 mapper:
http://www.virtualdj.com/addons/download.html?addon_id=2401
This will allow you switch the jogwheels between pitch bending (Default) and scratch. You can also file browse using the jogwheels too.
It also allows you to control a lot more of VDJ, with modes for manipulating effects, video and samples.
geposted Sun 23 Sep 07 @ 8:51 pm
