I just got the numark total control, and I love it so far. My only problem is that I hear crackling sound whenever i use the volume fader and even with the eq knobs. is therre a way i can improve the sound quality? is there a way I can eliminate those crackling sound?
thanks a bunch
thanks a bunch
geposted Fri 21 Sep 07 @ 10:01 pm
what is your system spec
what version do you use?
which soundcard?
which soundcard?
geposted Fri 21 Sep 07 @ 10:05 pm
system spec:
2 gig ram
160 gig HD
amd anthlon 64x2 processor
I use vdj 5 rev 2
i didnt get my sound card yet but im goin to be using numark dj/io.
right now im just plugging the usb directly to one of the ports in my comp. I just want to play around you know?
2 gig ram
160 gig HD
I use vdj 5 rev 2
geposted Fri 21 Sep 07 @ 10:09 pm
try on options > performances ,
choose fastest , autolatency untick safe and overclock
built in soundcards can have difficulies on higher settings as they arnt that great quality
the dj/io would be better :)
geposted Fri 21 Sep 07 @ 10:11 pm
thanks skyfxl.. i cant wait for my sound card to come in today. how can I register tc on here? can I?
geposted Fri 21 Sep 07 @ 10:12 pm
go to ur modify ur profile n enter at the software registration..after that u go back to the forum, ur logo is there:)
geposted Fri 21 Sep 07 @ 11:19 pm
thanksssss
geposted Sat 22 Sep 07 @ 12:36 am
