I recently purchased VirtualDJ 5. I have a USB Creative Sound Blaster Live 24 Bit External Sound Card and an External Stereo 4 Channel Mixer. (I do not have an internal soundcard in my PC). How do I play Deck 1 through the speakers while hearing Deck 2 through the headphones in order to create a mix.
Thanks
Thanks
geposted Sat 22 Sep 07 @ 2:58 pm
bigd
if you go into config then sound set up then choose external mixer on outputs you will see that you have now your white as left channel (1) and red as your right channell (2) all you need to do now is get a bridge for both of these channels so you have two inputs on the back of your mixer and your away, use them as normal or use one as your headphones... hope i've explained that okay for you
Tayla
Tayla
geposted Sat 22 Sep 07 @ 4:50 pm
