I was wondering if someone can tell me or give me feedback on the CDJ 800 Mk2s with Virtual dj. I am having a problem with timecode configuration one deck is showing full 100% the other changes from 100% to 60% to 40% it just does not stay at 100% and the quality of the sound changes when the numbers start changing.. I'm using the same timecode cd file on both decks..
These are my specs ..
server case pc rackmounted.
Asus M2n32sli deluxe Board
Nvidia nforce 590 sli chipset
8gb corsair DDR2 533mhz
AMD X2 dual core 6000 3.0 ghz cpu
Cool master 500watt powersupply
Nvidia gforce 8600 Gt Oc 256mb ddr3 In Sli configuration.
Sata3 500gb HD
2Numark Icdx
Serato Scratch Live Interface Box
2CDJ 800 Mk2
vestax vci 100
Thanks in advance
DJ Bori
Sights and Sounds Entertainment.
Sata3 500gb HD
2Numark Icdx
2CDJ 800 Mk2
vestax vci 100
Thanks in advance
DJ Bori
geposted Sat 22 Sep 07 @ 3:55 pm
Anybody got an answer for me??
geposted Sun 23 Sep 07 @ 8:16 pm
Did you burn your tccds exactly equal? I mean did you reduce -13 db both tccds?
geposted Tue 25 Sep 07 @ 6:13 pm
http://www.virtualdj.com/blog/moramax/?category=2
-> Signal Attenuator for djconsole mk2( to eliminate distorsions using cd player)
geposted Wed 26 Sep 07 @ 10:32 am
