Could someone please advise me on what video card to purchase to enable me to run karaoke on a seperate tv.
It will be used on a desktop pc using intel celeron 3.6ghz,512 ddr2 ram.
I currently have installed a nvidia geforce 7200 but i cannot get it to run karaoke on a seperate screen
Any help would be greatly appreciated
geposted Sat 22 Sep 07 @ 5:10 pm
Have you tried using the Nvidia control panel to run the multiple monitor setup. You can try using the dualview setting which will allow you to use different resolutions to match each monitor. Assuming your video casd has two video outputs.
geposted Sun 23 Sep 07 @ 7:38 pm
I think that is where the problem lies. It has 1 monitor output plus an s-video but I cannot get them both on simultaneously, it's either one or the other.
Could you recommend a card with dual outputs.
geposted Mon 24 Sep 07 @ 12:25 am
Plug in your television to the s-video port BEFORE you boot up your system. Windows should detect the television and you can make your adjustments with the Nvidia control panel as stated above. Hope this helps.
HOP
HOP
geposted Mon 24 Sep 07 @ 4:14 am
You will have lots of problems with that video card of the Le series, I would recommend you to get an ati radeon x-1300, it works fine.
geposted Tue 25 Sep 07 @ 6:26 pm
